roaming-assist-policy
Configures a roaming assist policy that enables access
points to assist wireless clients in making roaming decisions, such as which access point
to connect, etc.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
roaming-assist-policy <ROAMING-ASSIST-POLICY-NAME>
Parameters
| <ROAMING-ASSIST-POLICY-NAME> |
Specify the roaming-assist policy name. If a policy with the specified
name does not exist, it is created. |
nx9500-6C8809(config)#roaming-assist-policy test
nx9500-6C8809(config-roaming-assist-policy-test)#?
Roaming Assist Mode commands:
action Configure action - action is deauth / log /
assisted-roam
aggressiveness Configure the roaming aggressiveness for a wireless
client
detection-threshold Configure the detection threshold - when exceeded,
client monitoring starts
disassoc-time Configure the disassociation time - time after which a
disassociation is sent
handoff-count Configure the handoff count - number of times client
can exceed handoff threshold
handoff-threshold Configure the handoff threshold - when exceeds an
action is taken.
monitoring-interval Configure the monitoring interval - interval at which
client monitoring occurs
no Negate a command or set its defaults
sampling-interval Configure the sampling interval - interval at which
client rssi values are checked
clrscr Clears the display screen
commit Commit all changes made in this session
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no
Removes an existing roaming-assist-policy |
